Start/stop wireguard by shell
I have a B-1300.
In shell I run:
uci set wireguard.@proxy[0].enable=‘0’
uci commit wireguard
/etc/init.d/wireguard stop
Wireguard stopping correctly and in ui I can see the button connect.
In shell I run:
uci set wireguard.@proxy[0].enable=‘1’
/etc/init.d/wireguard restart
Wirguard starting but not connecting and in ui I can see error and button abort.
I have to reboot router to connecting again by wireguard.
Where is my error?
Perhaps because I have several wireguard connection profile?
thanks
This is the output for stopping:
root@GL-B1300:~# /etc/init.d/wireguard stop
md5sum: can’t open ‘/etc/os-release’: No such file or directory
  • Clearing IPv4 filter table
  • Clearing IPv4 nat table
  • Clearing IPv4 mangle table
  • Clearing IPv4 raw table
  • Populating IPv4 filter table
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
    • Rule ‘Allow-DHCP-Renew’
    • Rule ‘Allow-Ping’
    • Rule ‘Allow-IGMP’
    • Rule #7
    • Rule #8
    • Rule ‘guestzone_DHCP’
    • Rule ‘guestzone_DNS’
    • Rule ‘safe_mode_lan’
    • Rule ‘safe_mode_guest’
    • Forward ‘lan’ → ‘wan’
    • Forward ‘guestzone’ → ‘wan’
  • Populating IPv4 nat table
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
  • Populating IPv4 mangle table
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
  • Populating IPv4 raw table
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
  • Clearing IPv6 filter table
  • Clearing IPv6 mangle table
  • Clearing IPv6 raw table
  • Populating IPv6 filter table
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
    • Rule ‘Allow-DHCPv6’
    • Rule ‘Allow-MLD’
    • Rule ‘Allow-ICMPv6-Input’
    • Rule ‘Allow-ICMPv6-Forward’
    • Rule #7
    • Rule #8
  • Populating IPv6 mangle table
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
  • Populating IPv6 raw table
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
  • Set tcp_ecn to off
  • Set tcp_syncookies to on
  • Set tcp_window_scaling to on
  • Running script ‘/etc/firewall.user’
    uci: Entry not found
    iptables: No chain/target/match by that name.
    ipset v6.24: The set with the given name does not exist
  • Running script ‘/var/etc/gls2s.include’
    ! Skipping due to path error: No such file or directory
  • Running script ‘/usr/bin/glfw.sh’
  • Running script ‘/usr/sbin/glqos.sh’
  • Running script ‘/var/etc/mwan3.include’
  • Flushing conntrack table …
    /etc/rc.common: eval: line 1: =: not found
    Command failed: Not found
    killall: iface-mgr: no process killed
    cat: can’t open ‘/sys/class/net/ath0/address’: No such file or directory
    sh: bad number
    Interface doesn’t accept private ioctl…
    stafwd (8BE0): Invalid argument
    Error for wireless request “Set ESSID” (8B1A) :
    SET failed on device ath0 ; Invalid argument.
    sh: 0: unknown operand
    OK
    setHwaddr (8BE4): Device or resource busy
    cat: can’t open ‘/sys/class/net/ath1/address’: No such file or directory
    sh: bad number
    SET failed on device ath1 ; Invalid argument.
    OK
    rm: can’t remove ‘/tmp/dnsmasq.d/resolvfile’: No such file or directory
    cat: can’t open ‘/tmp/resolv.conf.vpn’: No such file or directory
    sh: bad number
This is the outputo for restarting (not working):
root@GL-B1300:~# /etc/init.d/wireguard restart
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
    • Rule ‘Allow-Ping’
    • Rule ‘Allow-IGMP’
    • Rule #7
    • Rule #8
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
    • Rule ‘Allow-MLD’
    • Rule #7
    • Rule #8
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
    • Zone ‘lan’
    • Zone ‘wan’
    • Zone ‘guestzone’
    sh: bad number
    OK
    sh: bad number
    OK
    sh: bad number
I have revolver deleting
during stop and start wireguard and it’s ok.
