Running Firmware 3 on MT300N-V2 I have setup Shadowsocks as a client. I want to be able to start it from command line. When I do a “service shadowsocks start” after clean boot, nothing happens.
When I start and stop shadowsocks from the GUI then service shadow socks command works.
Is there anyway I can initiate shadow socks from command line using the same command the GUI runs when I hit connect ?
Or is there a UCI set parameter that I can config to enable shadowsocks (like with wireguard - uci set wireguard.@proxy[0].enable=‘1’).
thx
