is there a way to download the “Static IP Address Binding” to txt or xls
Maybe you could select all table items and right-click to copy them, then paste them into txt?
This tool may be helpful if you know how to enable the debugging tool in your browser and copy the table in html: Convert HTML Table to Excel - Table Convert Online
Finally, can you tell us why you need to export the IP-MAC list?
You can just download /etc/config/dhcp or do a backup and extract dhcp file.
