Status of flint 4.x firmware
Hello!
Just bought a Flint and I was wondering what is the current advice on the firmware to use. I upgraded to the latest beta 4.x but reading more posts on the forum I am not sure that was a good idea.
What would you suggest from a newly router not yet configured? Stay on 3.x or upgrade? (I am especially looking at the improvements of vpn clients servers management)
Thanks
Per your need description above, 4.x is the way to go.
4 works nice with one BIG exception compared to 3.214…
4 misses option for some IP to bypass vpn and go through plain internet :frowning:
It should be there. Only fixed a bug in 4.0.2.
Any 4.0.2 update? cheers
heelllooooooo :rofl: is anyone there with firmwareeeeeeeee
maybe I have to stalk and catch a wild firmware
what is the latest beta firmware in flint router? in this version the gl-qos and the sqm-qos is working and can be installed via luci? thanks
