Strange Entries in History Page
Hi, this morning when I open my “history” page of my goodcloud account I see this entries. I try to search in others topic for a solution but I found nothing about this. I’ve try to include a screenshot in this topic, to show the error, but I don’t think to succeeded. Can you help me? Thanks.
History
All Device log Operation log Others
  • 2023-09-09 09:43
devicesList.{“api”:“/remote_ssh/set”,“dev_id”:“7a9d4451725f48e19a923309582af07a”,“enable”:true,“rtty_host”:“rtty-ssh-eu-2.goodcloud.xyz”,“rtty_port”:“59127”,“rtty_token”:“90aeec45c2f121538c27e1f7669a47a0”,“rtty_type”:“ssh”}
  • 2023-09-09 02:25
devicesList.{“api”:“/remote_ssh/set”,“dev_id”:“1516700ba6d44900a10b96df7e4cc65d”,“enable”:true,“rtty_host”:“rtty-ssh-eu-2.goodcloud.xyz”,“rtty_port”:“59127”,“rtty_token”:“bdf88cdb77282dc1015f28d119ca4d9e”,“rtty_type”:“ssh”}
  • 2023-09-09 02:24
devicesList.{“api”:“/remote_ssh/set”,“dev_id”:“783394bbea534545b3bdbf96eb4facfd”,“enable”:true,“rtty_host”:“rtty-ssh-eu-2.goodcloud.xyz”,“rtty_port”:“59127”,“rtty_token”:“bdf88cdb77282dc1015f28d119ca4d9e”,“rtty_type”:"we
It seems that it was accessed around 02:00 am by Windows edge and ssh using the same token then was ssh with a different token. weird. I would change some passwords and enable 2FA.
I posted about this earlier:
Gslb-us.goodcloud.xyz
I’ve new messagges! The two factor login it isn’t a secure way for block possible problem of this kind?
Is this a issue? @clannad
I have no idea. The only reason that I started this topic it’s because I hoping that someone could tell me what those lines of code they are, who or what could have originated them, and if I should worry or not. :confused:
It just the log request the ssh session from GoodCloud,it is not user friendly and the log feature will be improve in the future version.
