I've got the GL.iNet GL-MT1300 (Beryl). I'm using it in place of the router that comes with my RV. The router that comes with the RV locks you in on either not having Wi-Fi or paying for their internet plans.
I've always had 2 problems:
1. When using the OneConnect app (the android app that interfaces with the RV through the router), it seems like there is a constant timeout that happens once a minute where everything goes offline and then reconnects. Wifi still shows as connected the whole time.
I'm not sure anything can be done about it as I don't know if it's something with the router settings or if its the RV gateway that is hiccuping because of incompatibility from expecting a different router. Any ideas of how to diagnose this or at least to figure out if it's the router that's causing this? (maybe some security thing or some way it's handling traffic routing?)
2. Occasionally, I can't get connected to a wifi at an RV park. I'm never sure why. Every other hardware I have can connect but not this. It connects and doesn't give me internet or it tries to connect and just drops.
I may have an idea of what could be causing this. I never had visible errors, but I just updated the firmware from the old 3.x to the new OpenWRT 4.x based one. After connecting to my home WIFI..... Everything works but I see an error that says "LAN subnet is in conflict with the WAN subne, Please Change Lan Subnet to a different address’’.
I'm not sure why everything works if I get that error, but it does. What I wonder is if there is a quirk in why it still works on mine when it encounters this issue but not on others.
I can't change the router's IP address of 192.168.1.2 because I have to use the exact one as the factory router for it to interface and work with the RV. This also means I can't change the Subnet start/end to resolve the conflict.
Any suggestions?
