Recently it has happened 2 times that I use the Beryl to connect to wifi at a hotel as well as a public library and after getting the “success” popup no IP shows under the “Internet” tab. Even after several seconds. Suggestions?
Have you upgraded to 3.215?
Sometimes the router does needs time to get IP.
If it does not, can you get the system log?
Yes, updated to 3.215
Here are the logs.
Mon Oct 3 20:47:54 2022 kern.warn kernel: [ 670.430000] ExtEventBeaconLostHandler::FW LOG, Beacon lost (94:83:c4:1b:42:bc), Reason 0x10
Mon Oct 3 20:47:54 2022 kern.warn kernel: [ 670.438454] Beacon lost - AP disabled!!!
Mon Oct 3 20:48:00 2022 kern.warn kernel: [ 675.836537] [DfsCacNormalStart] Normal start. Enable MAC TX
Mon Oct 3 20:48:00 2022 kern.warn kernel: [ 675.842371] scan_ch_restore,central ch=42,bw=2
Mon Oct 3 20:48:00 2022 kern.warn kernel: [ 676.462589] ExtEventBeaconLostHandler::FW LOG, Beacon lost (94:83:c4:1b:42:bb), Reason 0x10
Mon Oct 3 20:48:00 2022 kern.warn kernel: [ 676.477053] Beacon lost - AP disabled!!!
Mon Oct 3 20:48:12 2022 user.info : saved ssid ignore: WPPL-PUBLIC 0
Mon Oct 3 20:48:12 2022 user.info : [ 810] gl-sdk>> bIsSaved=0, ssid=WPPL-PUBLIC, encryption=none, bssid=7A:8A:20:24:92:CF, wds=0, device=mt7615e2, identity=, channel=6
Mon Oct 3 20:48:12 2022 user.info : [ 2844] gl-wifi-core>> bIsStaEnabled=1
Mon Oct 3 20:48:12 2022 daemon.notice netifd: wwan (20478): udhcpc: received SIGTERM
Mon Oct 3 20:48:12 2022 daemon.notice netifd: Interface 'wwan' is now down
Mon Oct 3 20:48:12 2022 daemon.notice netifd: Interface 'wwan' is disabled
Mon Oct 3 20:48:17 2022 user.info : call apcli
Mon Oct 3 20:48:17 2022 user.info : call apcli sub
Mon Oct 3 20:48:17 2022 daemon.info apcli[23179]: ifname: apclix0, ssid: "WPPL-PUBLIC", enc: "none", key: "", bssid: 7A:8A:20:24:92:CF, channel: 6, network: wwan
Mon Oct 3 20:48:17 2022 kern.warn kernel: [ 678.537416] scan_ch_restore,central ch=6,bw=0
Mon Oct 3 20:48:17 2022 kern.warn kernel: [ 693.361979] (ApCliCtrlDeAuthAction) MLME Request Disconnect.
Mon Oct 3 20:48:17 2022 kern.warn kernel: [ 693.373914] APCLI AUTH - ApCliMlmeDeauthReqAction (state=0), reset AUTH state machine
Mon Oct 3 20:48:17 2022 kern.warn kernel: [ 693.381775] !!! APCLI LINK DOWN - IF(apcli1) (Reason=send deauth req,sub=apcli if down)!!!
Mon Oct 3 20:48:17 2022 kern.warn kernel: [ 693.391904] wifi_sys_linkdown(), wdev idx = 13
Mon Oct 3 20:48:17 2022 kern.warn kernel: [ 693.397529] bssUpdateBmcMngRate (BSS_INFO_BROADCAST_INFO), CmdBssInfoBmcRate.u2BcTransmit= 0, CmdBssInfoBmcRate.u2McTransmit = 0
Mon Oct 3 20:48:17 2022 daemon.info apcli[23179]: set apclix0 up
Mon Oct 3 20:48:17 2022 daemon.notice netifd: Network device 'apclix0' link is down
Mon Oct 3 20:48:17 2022 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Mon Oct 3 20:48:17 2022 kern.warn kernel: [ 693.411148] apclix0: ===> apcli_virtual_if_close
Mon Oct 3 20:48:17 2022 kern.warn kernel: [ 693.416285] wifi_sys_close(), wdev idx = 13
Mon Oct 3 20:48:17 2022 daemon.info apcli[20176]: set apclix0 down
Mon Oct 3 20:48:17 2022 daemon.info apcli[20176]: exit
Mon Oct 3 20:48:18 2022 daemon.info apcli[23179]: disconnected
Mon Oct 3 20:48:18 2022 daemon.info apcli[23179]: check bw...
Mon Oct 3 20:48:18 2022 kern.warn kernel: [ 694.415794] Set_ApCli_Enable_Proc : interface is not up, please do ifconfig up first
Mon Oct 3 20:48:18 2022 kern.warn kernel: [ 694.423887] IsHcRadioCurStatOffByWdev(): wdev_idx 13 obj is not ready, return TRUE !!!
Mon Oct 3 20:48:18 2022 kern.warn kernel: [ 694.432062] set_apcli_del_pmkid_list:: Delete PMKID list (1)
Mon Oct 3 20:48:18 2022 kern.warn kernel: [ 694.438129] [PMF]Set_ApCliPMFMFPC_Proc:: Desired MFPC=1
Mon Oct 3 20:48:18 2022 kern.warn kernel: [ 694.443762] [PMF]Set_ApCliPMFMFPC_Proc:: Security is not WPA2/WPA2PSK/WPA3PSK AES
Mon Oct 3 20:48:18 2022 kern.warn kernel: [ 694.451271] [PMF]Set_ApCliPMFMFPC_Proc:: MFPC=0, MFPR=0, SHA256=0
Mon Oct 3 20:48:18 2022 daemon.info apcli[23179]: start connect: 'WPPL-PUBLIC', OPEN, NONE 6
Mon Oct 3 20:48:18 2022 kern.warn kernel: [ 694.458288] Set_ApCli_Enable_Proc : interface is not up, please do ifconfig up first
Mon Oct 3 20:48:19 2022 user.info : [ 817] gl-sdk>> wifi_join return=0, channel=-1
Mon Oct 3 20:48:28 2022 daemon.info apcli[23179]: set apclix0 down
Mon Oct 3 20:48:28 2022 daemon.err apcli[23179]: connect error!!!!! re-connect in 60s
Mon Oct 3 20:48:28 2022 kern.warn kernel: [ 704.543409] Set_ApCli_Enable_Proc : interface is not up, please do ifconfig up first
The log shows that connection to the WiFi is failed. Maybe the WiFi network just don’t allow routers to connect.
How would the AP know it is a router connecting? Also, is there any way to get the exact error that happened during the connection?
I’m seeing the same logs - trying to connect to hotel wifi which is open (no security) but no captive portal either.
Phone, Linux laptop just connect without issues (no need to register device either).
The Beryl (3.215 then factory reset) says “success” and returns to the main screen but then nothing, no IP, no connection.
Any idea of a workaround?
Wed Sep 21 04:20:52 2022 kern.warn kernel: [ 161.969618] !!! APCLI LINK DOWN - IF(apcli1) (Reason=send deauth req,sub=apcli if down)!!!
Wed Sep 21 04:20:52 2022 kern.warn kernel: [ 161.979759] wifi_sys_linkdown(), wdev idx = 13
Wed Sep 21 04:20:52 2022 kern.warn kernel: [ 161.984876] bssUpdateBmcMngRate (BSS_INFO_BROADCAST_INFO), CmdBssInfoBmcRate.u2BcTransmit= 0, CmdBssInfoBmcRate.u2McTransmit = 0
Wed Sep 21 04:20:52 2022 daemon.info apcli[8802]: set apclix0 up
Wed Sep 21 04:20:52 2022 daemon.notice netifd: Network device 'apclix0' link is down
Wed Sep 21 04:20:52 2022 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Wed Sep 21 04:20:52 2022 kern.warn kernel: [ 161.998998] apclix0: ===> apcli_virtual_if_close
Wed Sep 21 04:20:52 2022 kern.warn kernel: [ 162.003777] wifi_sys_close(), wdev idx = 13
Wed Sep 21 04:20:52 2022 daemon.info apcli[4557]: set apclix0 down
Wed Sep 21 04:20:52 2022 daemon.info apcli[4557]: exit
Wed Sep 21 04:20:53 2022 daemon.info apcli[8802]: disconnected
Wed Sep 21 04:20:53 2022 daemon.info apcli[8802]: check bw...
Wed Sep 21 04:20:53 2022 kern.warn kernel: [ 163.004613] Set_ApCli_Enable_Proc : interface is not up, please do ifconfig up first
Wed Sep 21 04:20:53 2022 kern.warn kernel: [ 163.012464] IsHcRadioCurStatOffByWdev(): wdev_idx 13 obj is not ready, return TRUE !!!
Wed Sep 21 04:20:53 2022 kern.warn kernel: [ 163.020779] set_apcli_del_pmkid_list:: Delete PMKID list (1)
Wed Sep 21 04:20:53 2022 kern.warn kernel: [ 163.026772] [PMF]Set_ApCliPMFMFPC_Proc:: Desired MFPC=1
Wed Sep 21 04:20:53 2022 kern.warn kernel: [ 163.031974] [PMF]Set_ApCliPMFMFPC_Proc:: Security is not WPA2/WPA2PSK/WPA3PSK AES
Wed Sep 21 04:20:53 2022 kern.warn kernel: [ 163.039497] [PMF]Set_ApCliPMFMFPC_Proc:: MFPC=0, MFPR=0, SHA256=0
Wed Sep 21 04:20:53 2022 daemon.info apcli[8802]: start connect: 'PHG WIFI', OPEN, NONE 6
Wed Sep 21 04:20:53 2022 kern.warn kernel: [ 163.046227] Set_ApCli_Enable_Proc : interface is not up, please do ifconfig up first
Wed Sep 21 04:20:54 2022 user.info : [ 817] gl-sdk>> wifi_join return=0, channel=-1
Wed Sep 21 04:21:03 2022 daemon.info apcli[8802]: set apclix0 down
Wed Sep 21 04:21:03 2022 daemon.err apcli[8802]: connect error!!!!! re-connect in 60s
Wed Sep 21 04:21:03 2022 kern.warn kernel: [ 173.133155] Set_ApCli_Enable_Proc : interface is not up, please do ifconfig up first
config wifi-device 'mt7615e5'
option type 'mtk'
option hwmode '11ac'
option htmode 'VHT80'
option band '5G'
option txpower '20'
option noscan '1'
option region '7'
option cfg '/etc/wireless/mt7615_5g.dat'
option channel '48'
config wifi-iface 'wifi5g'
option device 'mt7615e5'
option network 'lan'
option mode 'ap'
option ssid 'GL-MT1300-38e-5G'
option encryption 'psk2'
option key 'goodlife'
option disassoc_low_ack '0'
option ifname 'ra0'
option wds '1'
config wifi-device 'mt7615e2'
option type 'mtk'
option band '2G'
option txpower '20'
option noscan '1'
option region '0'
option cfg '/etc/wireless/mt7615_2g.dat'
option hwmode '11ng'
option htmode 'HT20'
option channel '6'
config wifi-iface 'wifi2g'
option device 'mt7615e2'
option mode 'ap'
option ssid 'GL-MT1300-38e'
option wds '1'
option ifname 'rax0'
config wifi-iface 'guest5g'
option network 'guest'
option mode 'ap'
option wds '1'
option ssid 'GL-MT1300-38e-Guest-5G'
option ifname 'ra1'
option disabled '1'
option guest '1'
config wifi-iface 'guest2g'
option mode 'ap'
option wds '1'
option ssid 'GL-MT1300-38e-Guest'
option ifname 'rax1'
option disabled '1'
option guest '1'
config wifi-iface 'sta'
option network 'wwan'
option mode 'sta'
option ifname 'apclix0'
option ssid 'PHG WIFI'
option bssid '04:18:D6:AD:FB:70'
option channel '6'
option encryption 'none'
option disabled '0'
UPDATE: I’ve just tried the beta firmware for the Beryl and it seems to have fixed the problem
This seems a very good news!
It worked well but after a few days, the Beryl suddenly became unresponsive, no wifi and no access over eithernet. I did a full factory reset (back to the clean beta firmware) and set it up again, and it was fine again for the next few days. It worked through to the end of my trip.
