I have read through every info i could find. But after almost three days of frustration i have to ask for help.
The aim is to add a Wifi dongle (TL-WN722N v1) to a GL-MT300N-V2-ab1 which should connect to a existing AP via a high gain antenna and extend the internet through the internal wifi device.
It seems the drivers (kmod-ath9k-htc) are installed correctly when i look at dmesg right?
[ 24.037798] usb 1-1: ath9k_htc: Firmware ath9k_htc/htc_9271-1.4.0.fw requested
[ 24.045381] usbcore: registered new interface driver ath9k_htc
[ 24.550536] usb 1-1: ath9k_htc: Transferred FW: ath9k_htc/htc_9271-1.4.0.fw, size: 51008
Then
rm -f /etc/config/wireless
wifi config
After it the new radio0 appears in my wireless config file as it should.
And now i have no clue what to do next. I wasn’t able to do anything with radio0. Whatever i do in /etc/config/wireless the new Wifi dongle doesn’t do anything. The light doesn’t even turn on or blinks.
When i install travelmate. I can use radio0 to scan networks. But other than that radio0 stays silent
The Wireless tab in LUCI is not there. So how do i set things up?
This is how my wireless config looks like:
config wifi-device ‘mt7628’
option type ‘mt7628’
option htmode ‘HT40’
option ht_txstream ‘2’
option ht_rxstream ‘2’
option hwmode ‘11g’
option noscan ‘0’
option txpower ‘20’
option txpower_max ‘20’
option country ‘US’
option region ‘0’
option band ‘2G’
option mimops ‘3’
option wmm ‘1’
option channel ‘10’config wifi-iface
option device ‘mt7628’
option network ‘lan’
option mode ‘ap’
option encryption ‘psk2’
option key ‘goodlife’
option ssid ‘GL-MT300N-V2-eb1’
option wds ‘1’
option disassoc_low_ack ‘0’
option ifname ‘ra0’config wifi-iface ‘sta’
option network ‘wwan’
option mode ‘sta’
option ifname ‘apcli0’
option ssid ‘Airtel-E5573-5656’
option bssid ‘98:9C:57:28:56:56’
option channel ‘10’
option key ‘h4442372’
option disabled ‘0’config wifi-device ‘radio0’
option type ‘mac80211’
option channel ‘11’
option hwmode ‘11g’
option path ‘platform/101c0000.ehci/usb1/1-1/1-1:1.0’
option htmode ‘HT20’
option disabled ‘0’config wifi-iface ‘default_radio0’
option device ‘radio0’
option mode ‘ap’
option ssid ‘OpenWrt’
option encryption ‘none’
Network config:
config interface ‘loopback’
option ifname ‘lo’
option proto ‘static’
option ipaddr ‘127.0.0.1’
option netmask ‘255.0.0.0’config globals ‘globals’
option ula_prefix ‘fdf9:bc04:96db::/48’config interface ‘lan’
option type ‘bridge’
option ifname ‘eth0.1’
option netmask ‘255.255.255.0’
option ip6assign ‘60’
option hostname ‘GL-MT300N-V2-eb1’
option ipaddr ‘192.168.8.1’config interface ‘wan’
option ifname ‘eth0.2’
option proto ‘dhcp’
option hostname ‘GL-MT300N-V2-eb1’config device ‘wan_dev’
option name ‘eth0.2’
option macaddr ‘e4:95:6e:44:2e:b1’config interface ‘wan6’
option proto ‘dhcpv6’
option disabled ‘1’config switch
option name ‘switch0’
option reset ‘1’
option enable_vlan ‘1’config switch_vlan
option device ‘switch0’
option vlan ‘1’
option ports ‘1 6t’config switch_vlan
option vlan ‘2’
option ports ‘0 6t’config interface ‘wwan’
option proto ‘dhcp’
option metric ‘20’
Interfaces:
Wireless Overview:
I have read that people did this successfully. But how? How do i use/activate the new USB dongle? I couldn’t even manage to see the MAC address of the WIFI dongle in Network → Interfaces. Even when i change mt7628 to radio0 in the wireless config. Why??
For any help i would be happy to donate some money.
Thank you
ED
P.S.: In the config files i deleted the guest interfaces to make this post smaller and easier to read.
