Just want to share that I manage to install OpenVPN server on my AR300M. It’s working great.
Guide you can find here:
you don’t need openssh-sftp-server because you have already another ssh server installed. I start from section :Setup OpenVPN, because I already have dns. How to fix WIndows authentication you can find in comments.
I’m using this router at home and its working flawless! I didn’t have any freeze or some other issue. Wifi is great and this router manage my network and servers without any problem. This shoudn’t be declare only as trevel router!
I’m using 2.26 firmware. I will not include my package list I don’t see why needed. All is included inside guide.
WAN port is connected to my ISP router. I open ISP router DMZ host for AR300M. Performance that I manage to test is around 20Mbit download but maybe more because I didn’t have place to test it because my ISP speed is bottleneck.
The problem for me is that i encounter several problems in post steps, specially about creating certificate authority:
clean-all
build-ca
build-dh
build-key-server c7
build-key-pkcs12 user1
MY PROBLEM:
root@GL-AR300M:/etc/ssl# build-ca
-ash: build-ca: not found
Hope you can post here other links where can find out what i´m doing wrong …
