On the latest 4.7 firmware beta. I was using Luci earlier today with no issue. Now, I login to the router with no trouble, but trying to access Luci refused to login. No error, just doesn't login.
ok, tried 8443 and it worked. No idea why 8080 is. no longer working. Force https is not enabled.
Did you configure or open port on the firewall side? I am still having the same issue.
That's not needed.
If you can SSH into your router, check which port is used right now by running netstat -tulpen | grep uhttpd and netstat -tulpen | grep nginx
Strange, It shows the port is listening on 8080 and 8443 but still not able to access. Weird
Try incognito tab. 8080 must be used with http only, 8443 must be used with https only.
Tried both way http and https, no luck. Lets see if i could find something else.
It works on 8443 for me
umm.. i am not sure what could be the issue, might downgrade to 4.6.9 if couldn't find any solutions
Just letting you know, Luci is working over the LAN but when i am trying to acess with goodcloud i can't access luci on 8443 and i don;t know if i am missing something?
Thanks
