Suggestion For Future Update
Is it possible to have a strict DNS option I know having AdGurard running causes a problem but it might help.
Can you explain in more details?
On the ASUS Merlin routers on the VPN client you can chose Strict, Relaxed, Exclusive and Disabled, when strict and you do a leak test it should not show more then one server with it on relaxed similar to what we have even with AdGuard off you get at least to different servers show on a leak test.
Description in Asus Merlin:
Spot on that’s the idea.
Yes it is good. We are improving on vpn polices and dns so will take these into consideration.
Thanks much appreciate, I still get problems obtaining a vpn client but a reboot sorts the problem out, once connected no problems at all.
