suggestion for improvement
Found this repo
Completely open source.
May be you can use parts of it's code to implement per-client passwords as it is requested feature from GL?
Thank you for your suggestion.
Since this project appears to differ quite significantly from OpenWRT, it may be difficult for us to directly reference or port its code. Please refer to their official FAQ — How is SPR different from OpenWRT?:
If your main goal is simply to assign separate passwords to different wireless clients, you may want to refer to the following thread instead (although it should probably only work on the OP firmware):
