Suggestion for UI (Make Address Reservation in "Clients" View visible)
In the "Clients" View, it is not clear which Clients have an address reservation IP address / fix IP Address. I always have to open the "Network --> LAN --> scroll down to Address Reservation" to view those. I have the Puli AX XE3000 with Software v4.7.4.
Can you please add some lock symbol or a Star * next to the IP Address view here, to easily visualize which Clients have an address reservation set by the user? Thanks.
We have added the function switch of reserved IP in SDK version 4.8, so he can see which devices have the reserved IP turned on.
You can check the beta test post:
