I’ll be traveling around South East Asia with a couple of friends for an entire year. Therefore, I believe it would be best for us to use a travel router when connected to the hotel wifi (or ethernet), an internet shop, a local coffee shop, etc. We’ll be mostly browsing, watching movies & shows, using cloud storage, plus the occasional download.
GOALS
For me, the router/repeater features are more important than the media features. The goal is to create our own private, secure network that only our devices can be part of, while still having good internet access.
• Always have the same SSID and password no matter where we go or how we connect.
Internet1 Hotel Wifi (SSID1&Pass1) >> Travel Router (MySSID&MyPass) >> Our devices
Internet2 Coffee Wifi (SSID2&Pass2) >> Travel Router (MySSID&MyPass) >> Our devices
Internet3 Ethernet >> Travel Router (MySSID&MyPass) >> Our devices
- Less wifi passwords being stored on our devices
- Less hassle having to setup Chromecast every time we are in a new place
• Keeping internet performance high would be a bonus, specially in 3rd world countries all over Southeast Asia.
- Hopefully, the router/repeater would help boost the signal and connection strength.
• The ability to hide our SSID would be a bonus.
• The ability to share media from the router would be a bonus, but not important.
• The ability to use VPN would be a bonus (and I definitely need/want to learn more about VPN)
RESEARCH
I’ve read some of the posts by RangerZ and others and it seems like the new GL-AR300M fits the bill. However, can I set it up where I can have our network have a hidden personalized SSID and password?
Here are the top device choices based on what I’ve researched so far:
• GLI GL-AR300M - hardware, firmware and GUI makes this one of the best travel routers in it’s class
• Kingston MLWG3 - good choice, however, the router side is minimal, the media side is feature-rich
• HooToo TM-02 - GUI is basic and unsure if my desired setup is plausible)
• HooToo TM-06 - upgraded core, but my concerns are the same as with the TM-02
• InvizBox Go - new company, new device, VPN, although it has no ethernet port so no router?
• TP-LINK TL-WR810N - upgraded core, soon to have open firmware, has potential
• Any other device that fits the bill, insert here… (Coredy, RavPower, Comfast, etc)
QUESTIONS
• So which device would be best for my goals?
• Would you recommend using VPN when travelling South East Asia?
• If you do recommend the GL-AR300M:
- Should I get it with with two 2dbi external antennas or would the internal antennas be fine?
- Will the lockout issue still be an issue (no pun intended )? What approach would you recommend?
Thank you in advance for your time and suggestions…
