Thanks for your description. GoodCloud development engineers are on holiday, so checks may be a little late.
@clannad Please check the issue.
Could you share the device to me and make sure the device is online? My username in GoodCloud is yongping, I will check it for you.
Thx Clannad; just PMed you the device ID.
It’s online.
It is a bug of frontend and will be fixed in the next days.
The release 1.3.3 had beed updated, please try with your device again.
Sensational @clannad !
I can confirm the Goodcloud v.1.3.3 release enabled webadmin and ssh from the portal, so both now working.
Solved, and Thank you!
