I’d like to ask if you could consider adding support for OpenVPN configurations with XOR/obfuscation (such as NordVPN’s obfuscated TCP servers).
In some regions of the world, using standard VPN connections is not enough, and **obfuscated OpenVPN over TCP is often necessary** to bypass DPI and maintain a stable connection.
At the moment, these configs only work with specific clients (e.g., Tunnelblick), and cannot be used on routers due to the lack of client-side obfuscation support.
Adding support for this (e.g., XOR patch or similar obfuscation methods) would make GL.iNet routers much more effective in restricted networks.
Is this something you might consider for future firmware updates?
