Support of ExpressVPN Lightway on GL.iNet routers?
Now that ExpressVPN made public their Lightway protocol on GitHub, are there plans to support it on the GL.iNet routers? Thanks
I note that it is not yet supported to run on openwrt, and if it is packaged as a standard ipk file, we will consider putting it in our software repository.
Please...
You will save thousands
Oops. Didn't realize the date lol
Is it packaged as a standard ikp file now?
No, no ipk available so far.
But you can try: ExpressVPN in OpenVPN on OpenWrt - SUCCESS! - Installing and Using OpenWrt - OpenWrt Forum
Thx but Openvpn is blocked here. but thanks
I wanted to buy expressvpn Aircove but i guess i will wait for the ipk will be ready. because going from flint 2 to 1 is downgrade
Well, I doubt there will be an ipk in future.
Thanks so i will get Aircove portable. Theres a new version of Aircove called aircove Go. if u look it up here...
its a new. and it works like a gateway. liek its not a router anymore. it conencts to a router like Flint and then puts out VPNeized conenction.
Id be glad to hear you thought on it.
That's a Slate AX :joy::rofl::joy::rofl:
A gateway is a router, technically.
I guess it will just do the same like the GL in repeating mode or maybe in drop-in mode.
If it works; go for it. No real thoughts about it, tbh.
Yeah all expressvpn does is to steal GLinet routers and rebrand it lol.
I see some insider business here...
I think we as real GLinet customers must have access to whatever other companies do too with GLinet devices
