Surfshark on Brume 3 fails with "invalid login info [20001100]"
I saw several similar threads here over a fairly long period of them and those that I found were already auto-closed.
Any chance this known issue is finnally fixed and I don’t have to disable 2FA, install some phone apps and just use the GUI?
At present, if your Surfshark account has 2FA enabled, you will still need to use the mobile app to log in and use the service, or disable 2FA in order to use it via the WebUI.
We are planning to support this in the WebUI in a future release, but it is still under development and there is no specific version or timeline we can share at the moment.
