Anyone used Surfshark VPN with the GL-MV1000.
Thanks
Yes. What is the issue?
Here is guide to use surfshark
First get the vpn connection username and password
Download surfshark vpn zip and upload to the router, as this guide
Input your correct surfshark username and password.
Then choose the vpn profiles to connect.
Hi many thanks that’s great, no issue just wondering which VPN to use I’m with cyberghost (contract ending soon) but it don’t work, I had a word with their technical and they did say it wasn’t compatible.
I will give surfshark ago.
Really appreciate your post, have a great day
How about try WireGuard, much faster than OpenVPN
https://docs.gl-inet.com/en/3/tutorials/wireguard_client/#get-configuration-files-from-wireguard-service-providers
I’m wondering the exact same thing. I would love to edit the config files for wireguard client to work with surf shark.
I found this, but it’s not meant for people who don’t have networking experience at all.
I have Surfshark i would also like to know a simple solution too your not alone.
