I’m looking to swap the LAN and WAN ports on the Beryl AX in order to use the 2.5G port for my NAS, and the 1G port for regular internet. I’ve tried to swap things around as suggested in: https://www.reddit.com/r/GlInet/comments/16ilhfh/beryl_ax3000_swap_lan_wan/
but can only manage to get the 2.5G WAN to switch to a LAN via the interface toggle. When I try to make the 1G LAN a WAN via LuCI interface, it fails to act as a WAN port.
This is important to me because I’d like to use the Beryl AX as a bridge/access point for my main router (ideally I’d like to only use the main router for it’s DSL-modem capabilities - and use the Beryl AX as the ‘actual’ router). Unfortunately when I try to use the 1GB LAN as a WAN, the GliNet interface says I need to be connected in the WAN port before using the Beryl AX as an access point.
Could you also create a button in the interface that makes the 1G LAN port a 1G WAN port, or just swaps the WAN/LAN ports? (I’ve tried manually setting eth1 to WAN in the LuCI settings in a few different configurations, but they didn’t work)
