@AxeBro, I mean its potential usage. This is not in the default firmware.
Yes, I mean GLI UI. You can use this switch to disable it completely for security reason. However, you need to write script to modify http server and firewalls.
Thanks - I think that would be a cool use for it. though i’m starting to like the gli gui, so i’d probably keep it.
i’m wondering if I can use this to trigger/reset wifi config when the WISP provider isn’t around. So that I can access the gui without need for an ethernet cable.
I am currently using the wifiManager thta RangerZ posted a while back. Another option for me for the switch is to toggle between “private” hotspots (framily and friends) and “public”/free. This way I only have a handful of profiles to cycle through depending on where I am at.
anyone know how i may use the switch on the AR300M-Ext 128mb version ,to switch between the GL-iNET firmware installed on the 128mb NAND and Tor firmware installed on the NOR?
i am still figuring out how to get both firmware’s onto the AR300M-Ext.
We hadn’t been maintain tor firmware anymore. If you want to use it, you can upgrade to v3.x firmware, and install tor ipk. Here is a guide. Using Tor on GL.iNet's mini-routers - op-docs
