using gl-ap1300 with openwrt 22.03.2. When connecting the WAN ethernet cable and issuing the ‘reboot’ command, the boot hangs on the uboot init for a while, then boots up with a lot of warnings and finally comes up without working ethernet.
Note that this somehow seems related to the ethernet hardware to which the ap-1300 is connected: on some networks the boot is ok, on other network the issue happens.
any suggestions?
- is there a fix (maybe a newer bootloader?)
- is it possible to trigger a power cycle from the command line (instead of a reboot)?
- can I somehow reset the switch or eth phys completely after the reboot. I tried
swconfig dev switch0 set linkdown 1
swconfig dev switch0 set apply
as well as
cd /sys/devices/platform/soc/c000000.ess-switch/driver/
echo c000000.ess-switch > unbind
echo c000000.ess-switch > bind
but this re-triggers the same warnings. Neither command brings back the ethernet phys
- can I somehow shut down the switch or eth phys completely before reboot?
- any debug info that can help?
thnx
Tim
Serial console log (more complete logs in attachment seriallogs.zip (11.3 KB))
reboot
root@Ottie:/# [ 55.969047] ath10k_ahb a800000.wifi: peer-unmap-event: unknown peer id 1
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.BF.3.1.1-00120
S - IMAGE_VARIANT_STRING=DAABANAZA
S - OEM_IMAGE_VERSION_STRING=CRM
S - Boot Config, 0x00000021
S - Reset status Config, 0x00000010
S - Core 0 Frequency, 0 MHz
B - 261 - PBL, Start
B - 1339 - bootable_media_detect_entry, Start
B - 1678 - bootable_media_detect_success, Start
B - 1692 - elf_loader_entry, Start
B - 5069 - auth_hash_seg_entry, Start
B - 7211 - auth_hash_seg_exit, Start
B - 577089 - elf_segs_hash_verify_entry, Start
B - 694458 - PBL, End
B - 694482 - SBL1, Start
B - 785493 - pm_device_init, Start
D - 7 - pm_device_init, Delta
B - 786939 - boot_flash_init, Start
D - 52820 - boot_flash_init, Delta
B - 843898 - boot_config_data_table_init, Start
D - 3839 - boot_config_data_table_init, Delta - (419 Bytes)
B - 851109 - clock_init, Start
D - 7578 - clock_init, Delta
B - 863161 - CDT version:2,Platform ID:8,Major ID:1,Minor ID:1,Subtype:0
B - 866575 - sbl1_ddr_set_params, Start
B - 871672 - cpr_init, Start
D - 2 - cpr_init, Delta
B - 876055 - Pre_DDR_clock_init, Start
D - 4 - Pre_DDR_clock_init, Delta
D - 13177 - sbl1_ddr_set_params, Delta
B - 889794 - pm_driver_init, Start
D - 2 - pm_driver_init, Delta
B - 959926 - sbl1_wait_for_ddr_training, Start
D - 27 - sbl1_wait_for_ddr_training, Delta
B - 975546 - Image Load, Start
D - 152350 - QSEE Image Loaded, Delta - (297752 Bytes)
B - 1128325 - Image Load, Start
D - 1446 - SEC Image Loaded, Delta - (2048 Bytes)
B - 1138738 - Image Load, Start
D - 222252 - APPSBL Image Loaded, Delta - (454580 Bytes)
B - 1361388 - QSEE Execution, Start
D - 60 - QSEE Execution, Delta
B - 1367609 - SBL1, End
D - 675235 - SBL1, Delta
S - Flash Throughput, 2008 KB/s (754799 Bytes, 375847 us)
S - DDR Frequency, 537 MHz
U-Boot 2012.07 [Chaos Calmer 15.05.1,1619990+r49254] (Mar 24 2021 - 17:28:16)
smem ram ptable found: ver: 1 len: 3
DRAM: 256 MiB
machid : 0x8010100
NAND: spi_nand: spi_nand_flash_probe SF NAND ID 0:c2:12:c2
SF: Detected MX35LFxGE4AB with page size 2 KiB, total 128 MiB
SF: Detected W25Q32 with page size 4 KiB, total 4 MiB
ipq_spi: page_size: 0x100, sector_size: 0x1000, size: 0x400000
132 MiB
MMC:
In: serial
Out: serial
Err: serial
machid: 8010100
flash_type: 0
Net: MAC0 addr:94:83:c4:22:da:5e
PHY ID1: 0x4d
PHY ID2: 0xd0b1
<stays stuck here for 1-2 min>
then the kernel boots, but prints a lot of warnings
ipq40xx_ess_sw_init done
eth0
Hit "gl" key to stop booting: 0
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.146 (builder@buildhost) (arm-openwrt-linux-muslgnueabi-gcc (OpenWrt GCC 11.2.0 r19803-9a599fee93) 11.2.0, GNU ld (GNU Binutils) 2.37) #0 SMP Fri Oct 14 22:44:41 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: GL.iNet GL-AP1300
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000008fffffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x0000000087dfffff]
[ 0.000000] node 0: [mem 0x0000000087e00000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000088000000-0x000000008fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000008fffffff]
[ 0.000000] percpu: Embedded 15 pages/cpu s30860 r8192 d22388 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64960
[ 0.000000] Kernel command line: ubi.mtd=rootfs root=mtd:ubi_rootfs rootfstype=squashfs rootwait ubi.mtd=ubi root=/dev/ubiblock0_1
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 247172K/262144K available (6446K kernel code, 608K rwdata, 952K rodata, 1024K init, 246K bss, 14972K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 48.00MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb11fd3bfb, max_idle_ns: 440795203732 ns
[ 0.000008] sched_clock: 56 bits at 48MHz, resolution 20ns, wraps every 4398046511096ns
[ 0.000025] Switching to timer-based delay loop, resolution 20ns
[ 0.000326] Calibrating delay loop (skipped), value calculated using timer frequency.. 96.00 BogoMIPS (lpj=480000)
[ 0.000352] pid_max: default: 32768 minimum: 301
[ 0.000536] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000556] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001588] CPU: Testing write buffer coherency: ok
[ 0.001975] qcom_scm: convention: smc legacy
[ 0.002938] Setting up static identity map for 0x80300000 - 0x8030003c
[ 0.003100] rcu: Hierarchical SRCU implementation.
[ 0.003372] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.003745] smp: Bringing up secondary CPUs ...
[ 0.007312] smp: Brought up 1 node, 4 CPUs
[ 0.007338] SMP: Total of 4 processors activated (384.00 BogoMIPS).
[ 0.007349] CPU: All CPU(s) started in SVC mode.
[ 0.012119] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.012289] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.012316] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.012566] pinctrl core: initialized pinctrl subsystem
[ 0.014377] NET: Registered protocol family 16
[ 0.014761] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.015861] thermal_sys: Registered thermal governor 'step_wise'
[ 0.016301] cpuidle: using governor ladder
[ 0.016359] cpuidle: using governor menu
[ 0.041765] cryptd: max_cpu_qlen set to 1000
[ 0.046083] usbcore: registered new interface driver usbfs
[ 0.046157] usbcore: registered new interface driver hub
[ 0.046224] usbcore: registered new device driver usb
[ 0.046277] pps_core: LinuxPPS API ver. 1 registered
[ 0.046290] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.046318] PTP clock support registered
[ 0.048262] clocksource: Switched to clocksource arch_sys_counter
[ 0.049232] NET: Registered protocol family 2
[ 0.049487] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.050507] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.050573] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.050614] TCP bind hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.050664] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.050794] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.050838] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.051130] NET: Registered protocol family 1
[ 0.051180] PCI: CLS 0 bytes, default 64
[ 0.053658] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[ 0.058158] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.058183] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.186047] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.189559] bam-dma-engine 8e04000.dma: num-channels unspecified in dt
[ 0.189582] bam-dma-engine 8e04000.dma: num-ees unspecified in dt
[ 0.190282] tcsr 1949000.tcsr: setting wifi_glb_cfg = 41000000
[ 0.190382] tcsr 194b000.tcsr: setting usb hs phy mode select = e700e7
[ 0.190474] tcsr 1953000.ess_tcsr: setting ess interface select = 0
[ 0.190562] tcsr 1957000.tcsr: setting wifi_noc_memtype_m0_m2 = 2222222
[ 0.190881] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.192708] msm_serial 78af000.serial: msm_serial: detected port #0
[ 0.192757] msm_serial 78af000.serial: uartclk = 1843200
[ 0.192817] 78af000.serial: ttyMSM0 at MMIO 0x78af000 (irq = 33, base_baud = 115200) is a MSM
[ 0.192848] msm_serial: console setup on port #0
[ 0.742097] printk: console [ttyMSM0] enabled
[ 0.747242] msm_serial: driver initialized
[ 0.756320] loop: module loaded
[ 0.757383] spi_qup 78b5000.spi: IN:block:16, fifo:64, OUT:block:16, fifo:64
[ 0.759578] spi-nor spi0.0: w25q32 (4096 Kbytes)
[ 0.765623] 8 fixed-partitions partitions found on MTD device spi0.0
[ 0.770262] OF: Bad cell count for /soc/spi@78b5000/flash@0/partitions
[ 0.776532] OF: Bad cell count for /soc/spi@78b5000/flash@0/partitions
[ 0.783406] Creating 8 MTD partitions on "spi0.0":
[ 0.789387] 0x000000000000-0x000000040000 : "SBL1"
[ 0.794741] 0x000000040000-0x000000060000 : "MIBIB"
[ 0.799557] 0x000000060000-0x0000000c0000 : "QSEE"
[ 0.804163] 0x0000000c0000-0x0000000d0000 : "CDT"
[ 0.809071] 0x0000000d0000-0x0000000e0000 : "DDRPARAMS"
[ 0.813804] 0x0000000e0000-0x0000000f0000 : "APPSBLENV"
[ 0.818852] 0x0000000f0000-0x000000170000 : "APPSBL"
[ 0.824032] 0x000000170000-0x000000180000 : "ART"
[ 0.833028] spi-nand spi0.1: Macronix SPI NAND was found.
[ 0.833368] spi-nand spi0.1: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.839111] 1 fixed-partitions partitions found on MTD device spi0.1
[ 0.846908] Creating 1 MTD partitions on "spi0.1":
[ 0.853286] 0x000000000000-0x000008000000 : "ubi"
[ 1.290322] ESS reset ok!
[ 1.364585] ESS reset ok!
[ 1.948842] PHY 4 single test PSGMII issue happen!
[ 2.033119] PHY4 test see issue!
[ 2.107376] ESS reset ok!
[ 2.685792] PHY 4 single test PSGMII issue happen!
[ 2.770111] PHY4 test see issue!
[ 2.844387] ESS reset ok!
[ 3.422785] PHY 4 single test PSGMII issue happen!
[ 3.507094] PHY4 test see issue!
<boots to working command line>
but after this, eth1 (wich was connected and working before the reboot) does not come up:
Tue Jan 10 08:58:47 2023 kern.info kernel: [ 115.550263] ess_edma c080000.edma eth1: Link is Down
