I am looking at the following system log on my XE3000 which I am beginning to use with Cellular connection. I have SIM cards in both slots - sim2 active.
I have a connection to Vodafone UK and successful internet connection
But I see the following log every minute repeating.
Please can someone just explain what is happening. Is there anything misconfigured here?
Fri Jun 21 01:13:38 2024 daemon.notice netifd: modem_0001 (15447): [06-21_01:11:38:400] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Fri Jun 21 01:13:38 2024 daemon.notice netifd: modem_0001 (15447): [06-21_01:11:38:400] call_end_reason is 1
Fri Jun 21 01:13:38 2024 daemon.notice netifd: modem_0001 (15447): [06-21_01:11:38:400] call_end_reason_type is 2
Fri Jun 21 01:13:38 2024 daemon.notice netifd: modem_0001 (15447): [06-21_01:11:38:400] call_end_reason_verbose is 210
Fri Jun 21 01:13:38 2024 daemon.notice netifd: modem_0001 (15447): [06-21_01:11:38:400] try to requestSetupDataCall 60 second later
Thanks for prompt reply. Unfortunately this hasn't stopped the flow of the same messages in the log.
I am also now getting messages on my Windows laptop about needing to open a browser in order to complete connection to the GL-XE3000 5Ghz wifi service. The wifi is working ok but this is happening both before and after I rebooted the XE3000
Should I reverse the AT commands that you suggested? If so , how do I do that?
Maybe there is something about this SIM card initiating a connection back to Vodafone.
This is a new SIM, bought for the XE3000 , on a contract of unlimited (UK) calls, text and data.
As part of the set up, to check there is no PIN code set on the SIM card, I first inserted the SIM into my Samsung Galaxy S22 Ultra and powered up the phone.
My phone automatically downloaded and installed a Vodafone app.
Vodafone says this is to check where the phone is , & other things.
It does then make connections back to Vodafone to get data .
Is it possible that something on the SIM card is causing the XE3000 to try to make DataCalls back to Vodafone?
