*I've edited my post to place the point of it at the top in case someone wants to avoid the gritty details
.....So everyone be aware. If you order a line with static IP from T-Mobile, and then decide no static IP, the line will remain locked to an NSA only configuration. Apparently their provisioning system does not remove that config when static is removed. If you start with static IP, and then decide to pull it off, order a new line, and then kill the one with static IP. They do not know how to fix this.
>The rest of the story<
I've discovered something about T-Mobile that might be useful to others. We did a demo of their business 5G unlimited with static IP using one of their routers- They sent a Inseego 3100. Those are very low end devices. As is known, T-Mobile forces NSA, and has to route back to a data center someplace. Our demo routed to Washington state and we are on the USA east coast. Ping from the router to our location was in excess of 200 ms. Ping to 8.8.8.8 - probably local to their DC - from the router was over 100ms.
I ended up ordering a SIM on our account and they give three DC locations for static. Washington, Chicago, or Philadelphia. We chose PA. Ping from our router to an IP at our location was better, but still vaied around 100ms. Our use is backhaul of rtsp video from a camera. We found their static IP solution had lots of timing jitter, interpacket paths were diferent, so lots of out of sequence packets, and then some - ~1% - packet loss.
Here is the reason for the post, and it's important for others to be aware of. I configured an Ovpn tunnel back directly to us. I then had them remove the static IP from the line. Latency went down to around 60ms. But, here's the kicker. The radio still would only connect in NSA mode. Signal parameters looked terrible, and it limited the band selection. As a test, I put my TMHI SIM in the router (necessary adjustment made) and the same router, at the same location worked great - signals, latency, etc. I reported that the account was locked in NSA. Customer support said they saw that, but didn't know how to change it. Said it was the SIM is burned for that. Go get another SIM and we'll mode the line to it.
That did not fix it. NSA only. Much discussion back and forth. They blame the router. Never mind that it works fine with my SIM. I ordered another line WITH their router, That connects in SA mode. Move that SIM to the X3000 with the "repair" removed. Connects in SA mode. Original line SIM in X3000 again, and NSA only.
Original SIM in the Inssego router they sent, and NSA / 4G only. Newly ordered line SIM that came with the Inseego back in it, N41 SA with excellent rates.
Hopefully this helps others avoid the headache and waste of time.
