Tailscale and cloudflare warp
I'm with an issue that is driving me crazy as I'm unable to solve it or figure it out why it's happening on the first place.
I have two GL.iNet routers, one acting as a server for tailscale, and another one that is acting as travel router. Everything seems fine, I can connect to it, navigate, and do all sort of stuff as if I was on my home network. However, I have a problem when connecting cloudflare warp on my computer, as I get the following error in Cloudflare warp
Status: Unable to Connect
Error reason: DNS lookup failure
Error code: CF_DNS_LOOKUP_FAILURE
Error description: WARP is unable to resolve hostnames via its local DNS proxy. Try to verify your DNS connectivity or contact your administrator for assistance.
Learn more: Client errors · Cloudflare Zero Trust docs
It only happens when using it with tailscale. If I deactivate tailscale on the travel router works fine and if I connect directly to the server router it also works fine, so not sure what am I missing on the setup to ensure that cloudflare warp works as well.
Thank you!
