Hi All. I have this enviroment. I have two routers (brume 2 Firmware Version:4.4.6 | Router A and Router B)
As you can see the Router A is configured as “exit node”, well the problem is when I configured the Router B ,as a Client I mean as “Custom Exit node” assigning the “exit node ip” that got from the Router A (100.64.X.X), devices attached to Router B (LAN = 192.168.9.0/24) can’t go out to internet. If it works well I should go out via ISP Personal. Let me know how to fix it. Thanks
To understand better my idea I have done it before with OpenWrt (via lucy and SSH) and It worked perfect. Attached videos about it
