Hi, I’ve manage to get Tailscale somewhat function after tinkering with many setting, but the service seems to constantly disconnect and reconnect on my A1300. Is there something I can do to fix this. I bought the router specifically to use with Tailscale.
Okay, while I don’t use Tailscale I know it does use WireGuard ‘under the hood’ to connect everything up. Is there a way you can see if there’s an equivalent to persistent_keepalive '25'
? That’s used in most WG confs to keep ‘hearbeat’ like packets flowing.
