ive setup the comet poe and ive been using it as a kvm. I am however, unable to use it as an exit node. The device is already bound to my tailscale account, I already clicked as exit node, and already approved as exit node in tailscale.
However, if i use it as exit node in another device, it wont be able to access the internet. It just comes up with ‘This site cant be reached’ DNS_PROBE_FINISHED_BAD_CONFIG error. Any ideas?
Hi, I wonder which firmware version your Comet POE are in.
And could you export the log file to us for analysis? Via PM or email me (haoyu.zheng@gl-inet.com)
ive reentered the dns entry into resolv.conf and tried connecting from another device using glkvm as exit node (havent restarted glkvm) and it seems the same.
