tailscale Exit Node not working on GL-MT2500
i cant see any network on Exit Node from.
also how i can update tailscale from 1.66.4-1 (OpenWrt) to 1.78.1
I have the same issue with the GL-MT3000
Follow this: Script: Update Tailscale on (nearly) all devices
Thanks, i managed to update it manually by runing tailscale update works just fine.
i manage to make it work by running this command:
( tailscale up --accept-routes --advertise-exit-node --accept-dns=false --advertise-routes=xx.xx.xx.xx/24,192.168.8.0/24 )change the xx with your ips. u will need to run this command again evey time you will disable the tailscale & enable it again. hoppfully will be fixed in the next update.
