Yeah I ended up pasting the wrong info, only showing you that I’m able to ping google
… here’s the whole ordeal…
My setup:
Exit Node (Exit1): Linux machine set up as the exit node for my Tailscale VPN.
WSL2 on Windows Laptop: Configured to use Tailscale with Exit1 as its custom exit node, connecting through the AXT1800 travel router.
Issue: When connected via Tailscale to the exit node (Exit1), accessing Netflix results in SSL/TLS handshake failures from my WSL2 environment, while other connections, like Google, are successful.
Observations:
- Direct from Exit1: SSL/TLS connections to both Google and Netflix are successful, completing without issue.
- From WSL2 via Exit1: SSL/TLS connections to Google complete successfully; however, connections to Netflix hang at the SSL handshake phase.
With custom exit node enabled this command hangs on my machine.
From wsl2 w/ exit1 custom exit nod enabled.
openssl s_client -connect netflix.com:443 -servername netflix.com
CONNECTED(00000003)
^C
raz@Ubuntu-WSL2:~$ openssl s_client -connect google.com:443 -servername google.com
CONNECTED(00000003)
depth=2 C = US, O = Google Trust Services LLC, CN = GTS Root R1
verify return:1
depth=1 C = US, O = Google Trust Services LLC, CN = GTS CA 1C3
verify return:1
depth=0 CN = *.google.com
verify return:1
This curl command hangs right at SSL / TLS handshake, also from wsl2 (behind router w/ exit1 exit node enabled)
curl -vL --http1.1 https://netflix.com
* Trying 54.160.93.182:443...
* TCP_NODELAY set
* Connected to netflix.com (54.160.93.182) port 443 (#0)
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
Now if we run the commands directly on exit1, it’s able to complete the handshake.
raz@exit1:~$ openssl s_client -connect google.com:443 -servername google.com
CONNECTED(00000003)
verify return:1
verify return:1
verify return:1
raz@exit1:~$ openssl s_client -connect netflix.com:443 -servername netflix.com
CONNECTED(00000003)
depth=2 C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert Global Root CA
verify return:1
depth=1 C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert Secure Site ECC CA-1
verify return:1
depth=0 C = US, ST = California, L = Los Gatos, O = "Netflix, Inc.", CN = www.netflix.com
verify return:1
So really this causes issues w/ accessing some sites and also my bandwidth and jitter/latency is bad when I enable the custom exit node on the router.
