Tailscale on MT3000 not working
Running Tailscale on a brand new Gl.iNet mt3000 beryl AX.
Running the gl.iNet is 4.7.4.
Tailscale shows as logged in correctly and bound to my account. I also also see the node in Tailscale admin panel account.
If I try to access a node inside my Tailscale network, like a server or my home router, I get no response from the host on the Tailscale network.
Seems like Tailscale isn’t working as I’d expect. E.g when I connect to Tailscale network on my iPhone on cellular, I can access hosts on my home local network. This isn’t the case when Tailscale is active on the mt3000.
Please check if approve the subnet router of MT3000 in the Tailscale center.
Please SSH to the router MT3000, check if it can ping the Tailscale network IP like a server or home router.
I've checked on the router and in the Tailscale Admin console.
The client node is connected to Tailscale. They're no pending approvals in the Tailscale Admin console.
I've not set the MT3000 as a subnet router. As I understanding it, it's act as a client and not a server. My Tailscale nodes in my home network are set as subnet routers, and that's what allows me to login via my phone or work computer remotely and access hosts within the home subnet range. I don't have my phone set as a subnet router and that is able to access the home network without issues.
I've SSH'd into the MT3000 and can ping hosts like a router or homelab server node from he MT3000. I get a 30-40ms response time indicating it's running through the Tailscale network.
If I try to access the server / router / proxmox host through a browser, the page wont load.
I have no issues accessing the webpage UIs of any server or node when connected on my phone via Tailscale to my home Tailscale network.
Since the MT3000's LAN is a subnet, and tailscale network is depended on routing table, thus if the MT3000 LAN clients require to access Tailnet's resources (or say other tailscale clients), it needs to advertise this subnet route to all Tailnet clients.
