Tailscale regular disconnects
About every 2 weeks without having made any changes my Beryl router no longer talks to Tailscale and requires a full re-install. This is really irritating especially if I’m away from home and require connectivity.
Since Beryl - MT1300 is not on our supported list of GL Tailscale, we assume you are using a third-party Tailscale application.
Please try contacting the application's author for support, or consider writing a script to automatically restart the Tailscale when issues occur.
I’m not sure what you mean by “third party” It’s one of your applications
May we know this is a typo—it should be Beryl AX - MT3000, not Beryl - MT1300?
Alternatively, did you manually install gl-sdk4-tailscale on Beryl - MT1300?
When this issue occurs again, please:
  1. Let us know the model and the firmware version.
  2. SSH into the router and run the following command, then share the results with us:
tailscale status
  1. Export the device logs and send them to us via private message.
    How to export the device logs
    How to PM:
  2. Please make sure that "Disabled key expiry" in the Tailscale Admin Panel. Otherwise, manual reconfiguration is required after key expiration.
