Tailscale /usr/bin/gl_tailscale file changed?
I'm helping someone setup their GL.iNet Brume 2 with a Tailscale exit node. Previously (as of firmware version 4.2.1), I would simply replace the following line:
/usr/sbin/tailscale up --reset $param --timeout 3s
with
/usr/sbin/tailscale up --advertise-exit-node --reset $param --timeout 3s
But I'm not seeing this line in the file anymore when looking at the below file contents:
root@GL-MT2500:/# cat /usr/bin/gl_tailscale
#!/bin/sh
action="$1"
TS_POLICY_ROUTE=/tmp/ts_policy_route
TS_FIREWALL_SECTION=gltailscale
TAILSCALE_ROUTE_TABLE=52
TAILSCALE_DNS_SERVER="100.100.100.100"
if [ "$action" == "set_route" ];then
sleep 5
ip route add 100.64.0.0/10 dev tailscale0
fi
add_policy_route()
target=$1
if [ -n "$target" ]; then
route_param="to $target table main"
/sbin/ip rule add $route_param
echo $route_param >> $TS_POLICY_ROUTE
fi
del_policy_route()
/sbin/ip rule del to $TAILSCALE_DNS_SERVER lookup $TAILSCALE_ROUTE_TABLE pri 50
if [ -f $TS_POLICY_ROUTE ]; then
while read line; do
if [ -n "$line" ]; then
/sbin/ip rule del $line
fi
done < $TS_POLICY_ROUTE
rm $TS_POLICY_ROUTE
fi
add_guest_policy_route()
guest_disable=$(uci -q get network.guest.disabled)
exit_node_ip=$(uci -q get tailscale.settings.exit_node_ip)
if [ -n "$exit_node_ip" ] && [ "$guest_disable" == "0" ]; then
guestip=$(ubus call network.interface.guest status|jsonfilter -e '@["ipv4-address"][0].address')
guestmask=$(ubus call network.interface.guest status|jsonfilter -e '@["ipv4-address"][0].mask')
if [ -n "$guestip" ] && [ -n "$guestmask" ] ;then
guest_network=$(ipcalc.sh $guestip $guestmask | awk -F= '/NETWORK/{print $2}')
guest_mask=$(ipcalc.sh $guestip $guestmask | awk -F= '/PREFIX/{print $2}')
fi
if [ -n "$guest_network" ] && [ -n "$guest_mask" ]; then
guest_ip="$guest_network/$guest_mask"
policy_route_param="from $guest_ip table main"
/sbin/ip rule add $policy_route_param
echo $policy_route_param >> $TS_POLICY_ROUTE
fi
fi
add_exit_node_rule()
count=0
while [ $count -le 5 ]
do
rule_exist=$(ip rule | grep "from all fwmark 0x80000/0x80000 lookup")
ts_prio=$(ip rule | grep "from all lookup 52" |  awk -F':' '{print $1}' | head -n 1)
if [ "$rule_exist" == "" ]; then
if [ -n "$ts_prio" ]; then
pre_prio=$(($ts_prio-1))
policy_route_param="from all fwmark 0x80000/0x80000 lookup main prio $pre_prio"
fi
else
break
fi
count=$(($count+1))
sleep 1
done
add_ts_fw_rule()
if [ -f /etc/firewall.tailscale.sh ]; then
/etc/firewall.tailscale.sh &
fi
modify_dns_resolv()
dns_suffix=$(tailscale status -json | jsonfilter -e '@.MagicDNSSuffix')
rule_exist=$(grep "ts.net/100.100.100.100" /etc/dnsmasq.conf)
domain_orig=$(uci get dhcp.@dnsmasq[0].domain)
domain_orig_clean=$(echo "$domain_orig" | sed "s/.*ts.net //g")
if [ "$1" == "1" ]; then
[ "$dns_suffix" == "" ] && dns_suffix="ts.net"
echo "server=/$dns_suffix/100.100.100.100" >> /etc/dnsmasq.conf
uci set dhcp.@dnsmasq[0].domain="$dns_suffix $domain_orig_clean"
uci commit dhcp
/etc/init.d/dnsmasq restart
fi
else
uci set dhcp.@dnsmasq[0].domain="$domain_orig_clean"
uci commit dhcp
if [ -n "$rule_exist" ]; then
sed -i '/ts\.net\/100\.100\.100\.100/d' /etc/dnsmasq.conf
fi
fi
if [ "$action" == "restart" ];then
/etc/init.d/tailscale restart
del_policy_route
add_ts_fw_rule
sys_mode=$(uci -q get glconfig.general.mode)
if [ "$sys_mode" != "router" ]; then
/etc/init.d/tailscale stop
modify_dns_resolv 0
exit 0
fi
enabled=$(uci -q get tailscale.settings.enabled)
if [ "$enabled" == "1" ]; then
/sbin/ip rule add to $TAILSCALE_DNS_SERVER lookup $TAILSCALE_ROUTE_TABLE pri 50
wanip=$(ubus call network.interface.wan status|jsonfilter -e '@["ipv4-address"][0].address')
wanmask=$(ubus call network.interface.wan status|jsonfilter -e '@["ipv4-address"][0].mask')
if [ -n "$wanip" ] && [ -n "$wanmask" ] ;then
wan_network=$(ipcalc.sh $wanip $wanmask | awk -F= '/NETWORK/{print $2}')
wan_mask=$(ipcalc.sh $wanip $wanmask | awk -F= '/PREFIX/{print $2}')
fi
[ -n "$wan_network" -a -n "$wan_mask" ] && wan_ip="$wan_network/$wan_mask"
secondwanip=$(ubus call network.interface.secondwan status|jsonfilter -e '@["ipv4-address"][0].address')
secondwanmask=$(ubus call network.interface.secondwan status|jsonfilter -e '@["ipv4-addr
You will need to edit /etc/init.d/tailscale
I'm still not seeing a relevant "tailscale up" command in this file either.
root@GL-MT2500:~# cat /etc/init.d/tailscale
#!/bin/sh /etc/rc.common
# Copyright 2020 Google LLC.
# Copyright (C) 2021 CZ.NIC z.s.p.o. (https://www.nic.cz/)
# SPDX-License-Identifier: Apache-2.0
USE_PROCD=1
START=80
start_service() {
  local state_file
  local port
  local std_err std_out
  config_load tailscale
  config_get_bool std_out "settings" log_stdout 1
  config_get_bool std_err "settings" log_stderr 1
  config_get port "settings" port 41641
  config_get state_file "settings" state_file /etc/tailscale/tailscaled.state
  /usr/sbin/tailscaled --cleanup
  config_get enabled "settings" enabled 0
  if [ "$enabled" -eq "1" ];then
  procd_open_instance
  procd_set_param command /usr/sbin/tailscaled
  # starting with v1.48.1 ENV variable is required to enable autodetection of iptables / nftables
  procd_set_param env TS_DEBUG_FIREWALL_MODE=auto
  # Set the port to listen on for incoming VPN packets.
  # Remote nodes will automatically be informed about the new port number,
  # but you might want to configure this in order to set external firewall
  # settings.
  procd_append_param command --port "$port"
  procd_append_param command --state "$state_file"
  procd_set_param respawn
  procd_set_param stdout "$std_out"
  procd_set_param stderr "$std_err"
  procd_close_instance
  fi
stop_service() {
root@GL-MT2500:~#
How would you advise editing this file to achieve the same effect?
There is no tailscale up because it is a service.
You need to modify the param= line.
I would recommend to run GitHub - Admonstrator/glinet-tailscale-updater: This script updates the Tailscale installation on GL.iNet routers. which mostly take care about it.
Could you please elaborate how running the Tailscale update script would address what I'm trying to do, which is to enable the exit node function?
Ah, yeah, guess I was wrong. The exit node functionality seems to be enabled via GL GUI.
Huh? GL.iNet routers don't currently have a functionality to run the device as an exit node. The GUI setting for Tailscale is only for connecting to an existing exit node.
I don't use tailscale, so my information can be wrong, I am sorry for that.
I just checked it on my Flint2 (4.6.2, op-24) and found the necessary lines within
So not sure what is going on, but you seem to be right: There are different versions of gl_tailscale :gl_emoji_confused:
