Telstra sim
Hi I have just set up a new Glinet Spitz AX3000 router. It will access the network for a few minutes then stop. I am using a Australia Telstra sim. It then says that the sim is unregistered.
Please help?
If put this SIM card on your phone, is it always normal?
When using it on phone, do you need to manually enter APN? If not, please also need to check whether APN has info/content.
