Hi, im having trouble setting up a 2 router bridge-extender to get decent wifi in my office/shed in the garden
I have tried several configurations and cant really understand what the problem is.
Im always using two routers - one as a receiver of my home signal, the other as an emitter of wifi in the garden
The pair is connected via standard lan cable.and everything works, but the speeds are not good with certain configurations.
The one that works is:
Wifi ))))) [GL-AR300M-Ext/Shadow]-------(lan_cable)---------[TP-Link Archer C60] ))))) Laptop
No problems here, but i really want to retire the TP-Link Archer router as its old and makes annoying high pitched noise === 25mbps, 8ms ping average
Wifi ))))) [GL-AR300M-Ext/Shadow]-------(lan_cable)---------[GL-AR150/ White] ))))) Laptop
Wifi ))))) [GL-AR300M-Ext/Shadow]-------(lan_cable)---------[TP-Link TL-WR802N] ))))) Laptop
^when i use the small routers i achieve less then half of the network speed on either of those and also the ping is twice as high why ?
=== 7mbps, 16ms ping average
Tested multiple times one after another, i can always get the 25mbps on the big Archer c60, but never on any of the small routers (GL-AR 150 or TP-Link WR802N)
I got my laptop as close to them as possible and it doesn’t help.
I have been using the Archer C60 daily for a very long time now, all settings are default.
The networks are on different channels (Home network is on is ch1, output of tp/glinets is set to 6+10
Can anyone help me find out why this is like that ?
