I tend to use the tethering mode off my OnePlus Android phone all the time, I discovered a bug and I'm wondering if anyone has a solution for this.
By design once the phone reaches 100%, it disconnects the USBc port which then disconnects from the router which then disables the USB tethering option.
Is there a way to not charge the phone once connected to this router and only allow tethering to work?
I tried to play with the phone in the developer mode turned on I'm playing around with the USB setting but nothing seems to work. Any feedback is much appreciated.
