“Thu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Populating IPv6 mangle table\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Rule ‘process_mark’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Rule ‘wan_in_conn_mark’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Rule ‘lan_in_conn_mark_restore’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Rule ‘out_conn_mark_restore’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Zone ‘lan’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Zone ‘wan’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Zone ‘guest’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Zone ‘ovpnclient’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Set tcp_ecn to off\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Set tcp_syncookies to on\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Set tcp_window_scaling to on\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Running script ‘/etc/firewall.nat6’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Running script ‘/etc/firewall.vpn_server_policy.sh’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Running script ‘/var/etc/gls2s.include’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): ! Skipping due to path error: No such file or directory\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): * Running script ‘/usr/bin/gl_block.sh’\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): uci: Entry not found\nThu Dec 21 13:44:52 2023 daemon.notice netifd: ovpnclient (7202): cat: can’t open ‘/tmp/run/ovpn_resolved_ip’: No such file or directory\n”
It is hard to help without any description of the question.
When i try to connect NordVPN location.
The client is starting, please wait --FOREVER
Logs are attached in the description.
Do you have internet without vpn? Can you show how Dows the router connect to the internet?
- It’s connected wifi internet
- COnnected to NordVPN login with username/passwd
- Selected location
- Selected server
Then The message "The Client starting, please wait-FOREVER
NordVPN changed this to new credentials.
You can find your NordVPN service credentials (service username and service password) in the Nord Account dashboard:
Logs: “Fri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Populating IPv6 mangle table\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Rule ‘process_mark’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Rule ‘wan_in_conn_mark’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Rule ‘lan_in_conn_mark_restore’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Rule ‘out_conn_mark_restore’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Zone ‘lan’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Zone ‘wan’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Zone ‘guest’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Zone ‘ovpnclient’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Set tcp_ecn to off\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Set tcp_syncookies to on\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Set tcp_window_scaling to on\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Running script ‘/etc/firewall.nat6’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Running script ‘/etc/firewall.swap_wan_in_conn_mark.sh’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Running script ‘/etc/firewall.vpn_server_policy.sh’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Running script ‘/var/etc/gls2s.include’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): ! Skipping due to path error: No such file or directory\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): * Running script ‘/usr/bin/gl_block.sh’\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): uci: Entry not found\nFri Dec 22 14:40:33 2023 daemon.notice netifd: ovpnclient (24371): cat: can’t open ‘/tmp/run/ovpn_resolved_ip’: No such file or directory\n”
Are you located in an country where VPN is forbidden?
I am connecting to LOndon location, I have tried other location also same.
Seems like something is blocking the connection. How do you connect to the internet?
Connected through internet with Wifi connect
So with an upstream wifi router? Does this one block OpenVPN?
I have tried two different wifi. I am able to login directly with nordvpn.
Enabling through router an problem.
“Sat Dec 23 11:23:17 2023 daemon.notice ovpnclient[26124]: NOTE: --fast-io is disabled since we are not using UDP\nSat Dec 23 11:23:17 2023 daemon.notice ovpnclient[26124]: Outgoing Control Channel Authentication: Using 512 bit message hash ‘SHA512’ for HMAC authentication\nSat Dec 23 11:23:17 2023 daemon.notice ovpnclient[26124]: Incoming Control Channel Authentication: Using 512 bit message hash ‘SHA512’ for HMAC authentication\nSat Dec 23 11:23:17 2023 daemon.notice ovpnclient[26124]: TCP/UDP: Preserving recently used remote address: [AF_INET]103.107.199.147:443\nSat Dec 23 11:23:17 2023 daemon.notice ovpnclient[26124]: Socket Buffers: R=[87380->87380] S=[16384->16384]\nSat Dec 23 11:23:17 2023 daemon.notice ovpnclient[26124]: Attempting to establish TCP connection with [AF_INET]103.107.199.147:443 [nonblock]\nSat Dec 23 11:23:17 2023 daemon.notice ovpnclient[26124]: TCP connection established with [AF_INET]103.107.199.147:443\nSat Dec 23 11:23:17 2023 daemon.notice ovpnclient[26124]: TCP_CLIENT link local: (not bound)\nSat Dec 23 11:23:17 2023 daemon.notice ovpnclient[26124]: TCP_CLIENT link remote: [AF_INET]103.107.199.147:443\nSat Dec 23 11:23:17 2023 daemon.notice ovpnclient[26124]: TLS: Initial packet from [AF_INET]103.107.199.147:443, sid=54075865 480f76a9\nSat Dec 23 11:23:18 2023 daemon.notice ovpnclient[26124]: VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA\nSat Dec 23 11:23:18 2023 daemon.notice ovpnclient[26124]: VERIFY OK: depth=1, O=NordVPN, CN=NordVPN CA8\nSat Dec 23 11:23:18 2023 daemon.notice ovpnclient[26124]: VERIFY KU OK\nSat Dec 23 11:23:18 2023 daemon.notice ovpnclient[26124]: Validating certificate extended key usage\nSat Dec 23 11:23:18 2023 daemon.notice ovpnclient[26124]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication\nSat Dec 23 11:23:18 2023 daemon.notice ovpnclient[26124]: VERIFY EKU OK\nSat Dec 23 11:23:18 2023 daemon.notice ovpnclient[26124]: VERIFY X509NAME OK: CN=sg462.nordvpn.com\nSat Dec 23 11:23:18 2023 daemon.notice ovpnclient[26124]: VERIFY OK: depth=0, CN=sg462.nordvpn.com\nSat Dec 23 11:23:18 2023 daemon.notice ovpnclient[26124]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 4096 bit RSA, signature: RSA-SHA512\nSat Dec 23 11:23:18 2023 daemon.notice ovpnclient[26124]: [sg462.nordvpn**] Peer Connection Initiated with [AF_INET]103.107.199.147:443\n”
Can you confirm that you used the correct vpn connection username and password as @admon said.
Also try other servers.
I’m having the same problem can’t sep up any vpn, I tried North VPN manual connection. Tried also wireGuard with a flint 2 and a Beryl AX but none of them can connect to a VPN service through North VPN nor wireguard between them. I tried putting them on different networks using my phone in the beryl and Ethernet in my Flint 2. The client is starting please wait is the only message that appears attached is first the log for north VPN and the second is wireguard. Please help
The 1st one is easy: Wrong credentials.
Nord uses service credentials for VPN instead of the login credentials.
For the wiregaurd, pls check the following:
- The exact wireguard works on other devices, e.g. smartphone of pc
- The router has noral Internet
- You are not in a censored region.
