Hello, I’m a GL.iNet MT3000 router user and I’m currently facing an urgent issue that needs assistance.
When setting up the VPN, I imported an OpenVPN configuration file, but the router dashboard has been stuck on “Connecting” and cannot establish the VPN connection.
After that, my computer shows “No Internet access” at the bottom right corner, and once I closed the admin panel (192.168.8.1), I could no longer access it again.
Additionally, after this problem occurred, I tried connecting my computer to another working Wi-Fi network. Although it shows “Connected,” there is actually no Internet access—web pages won’t load and apps can’t connect. I’m not sure if this issue is related to the router problem.
Steps I’ve tried:
Restarted both the router and the computer.
Performed a factory reset (held the Reset button for 10 seconds).
Unfortunately, the problem still remains.
Current router LED status: steady white light.
Could you please advise how I can access the admin panel again or restore normal connection to the GL.iNet network?
