Open WRTR 19.07.3/ now available:
“Upgrading to OpenWrt 19.07.3
Upgrading from previous OpenWrt 19.07 versions is straightforward thanks to the sysupgrade utility: sysupgrade from web interface or sysupgrade from command-line.”
Source: [OpenWrt Wiki] OpenWrt 19.07.3 - Service Release - 20 May 2020
It may be that some of the a little more security conscious users are ready for a test of a more secure gl firmware…
Apple is supporting WPA3 since iOS Version 13
There are still issues to be resolved with WPA2/WPA3 interoperability…
It’s mostly on older devices that do support WPA2, but the new epigrams can/will cause issues here on the client side…
One other vendor of WiFi4 and WiFi5 router, which use open wrt 19.07.x firmware and support mixed mode forWPA2/3 Personal, reporting its need by some clients to reconnect once (setup the connection to the client new by typing the password). I have the same experience with WiFi5 router which supporting mixed WPA2/3 to WiFi6 client devices. No problems, after first new logon by typing wifi password.
Don’t confuse Wife 4/5/6 with WPA2/3 please…
Patches applied on AR150 on openwrt master, which is WiFi4, can support WPA3
sfx
I dont confuse this. I’ve changed the wording a little bit to make it more clear.
Great news. The stable of OpenWrt 19.07.4 are out now:
On openwrt.org are already available the 19.07.4 at minimum for p.e. follow mainstream router:
How about a release by gl ?
If I dont have seen wrong by one other vendor, on of minimum of his routers, offer now by same hardware a higher wifi channel bandwide and wifi speed. (changed from 20 to 40 MHz or from 40 too 80 MHz or like this by same Hardware)
For checking actual openwrt for other gl router, you can check on follow page:
