is it possible to get a step by step for dummies on how to set up TMHI , including IMEI and APN?
Regarding APN settings, there are many posts and discussions in the forum, and the GL Docs also have related tutorials.
We do not recommend users modify IMEI. This is the identifier of the device module.
After modification, it will cause the operator's network to be unable to access, and it will be even disabled in serious cases. For more detailed information, please contact support@gl-inet.com
Not sure what you are trying to do.
My TMHI is a gizmo that uses wireless to a wifi and ethernet out. The technical part should have been performed by TMO. You access via the app on phone to manage.
My LTE backup router and modem I take sim and put in then configure it via the web app to access tmo.
