Toggling between esim profiles requires manually changing APN settings
Hey,
I travel occasionally between different countries in Europe and need to change the esim profiles often in the GL-X3000 Applications -> eSIM Management.
Everytime I change the eSIM profile I need to again input APN settings. Would there be a way to develop the eSIM profile management to remember the connection profile as well?
This way I wouldn't need to everytime debug my router when changing the eSIM.
Hello, thanks for the suggestion. We will take this request into consideration and evaluate it.
Hi @onni X3000 beta version 4.8 will retain the manually configured APN information. Could you update router to this version and try it again?
