Hello, how can i disable or change settings for failed login attempts (default is 10min now) is this set somewhere in the file or in LUCI ? its possible reset timer by ssh ?
GL-E750/GL-E750V2 Mudi
Version: 4.3.8
Version: 4.3.8
Trying to break into the router, are we? If you can’t remember the root password, you’ll have to reflash. See the docs for specifics.
