TOR Connection issues on MUDI
Has anyone experienced connection issues when using a SIM card to connect to Tor?
I have been using this set up for a while, no issues on the same update (latest) a few weeks ago. When I boot the sim card connects TOR starts goes from 0-30% or 0-40% then disconnects from the internet and the loop continues, with perfect signal.
I have been using This set up for a while, no issues on the same update (latest)
When I boot the I reboot the device 5-6 times it will connect properly but will disconnect in a few hours and do the same thing!
Can anyone help?
Can you tell me which carrer you are using?
I use a major US carrier, it has worked fine for months. Now it is almost unusable takes 1 hour of booting and restarting it for it to connect for 30 minutes.
It is useless like this disappointed.
Ps: Add a bridges for Tor
Why do you ask my carrier is it a known issue ?
In the modem settings, can you change the mtu to 1428?
You can find mtu settings if set up manually.
How do I do that. Can you explain the steps.
Now I can usually connect on second or third restart. But the tor connection disconnects and requires me to restart . I will try your fix.
Thank you
The mtu can be set in luci
You should find the modem interface and set.
