Unfortunately Tor doesn`t work on my device.
Model AR300NAND showing in Config Tool (GL-AR300M labelt under the Box).
Firmware 2.25
File which I have tryed : openwrt-ar300m-nand-tor-1.4.tar
I got the message: <span style=“color: #ff0000;”>Error: Firmware is not for this Hardware.</span><b></b><i></i><u></u>
Has anyone an idea?
Many thx
alzhao
2
Seems your AR300M is working in Nor flash. Can you please check the SSID?
If it is Nor flash then the SSID will be “GL-AR300M-XXX-Nor”, while Nand firmware will just be “GL-AR300M-XXX”
Hello, thank you for your answer.My SSID is GL-AR300M-48d.
alzhao
4
Did you upgrade from old firmware and reserved the settings so the SSID was kept the same.
Can you please check the space space in “App Repo” page?
If it is 90MB+ it is Nand. Otherwise it is Nor.
