Installed the Tor firmware on my MT-300A and it works perfect as expected. I would like to install extra packages but the configured repo is pointing to 1.3 and in the repo list there is no 1.4 directory. http://www.gl-inet.com/openwrt/ramips/tor/
Is there any plan to add a 1.4 or is there a way to add the 1.3 keys to the 1.4?
Thank you. I was able to also just comment out the sig check option. I was hoping to install the SD card drivers but they don’t seem to work, as you say they are Kernel modules.
