Using 4-22 image for brume .onion addresses are not being resolved.
setup:
firefox 75
about:config network.dns.blockDotOnion set to false
bootstraped is 100% .
check.torproject.org gives the thumbs up
I even went into /etc/tor/torrc
and changed:
AutomapHostsSuffixes .exit,.onion
#AutomapHostsSuffixes “.”
update:
working now after…
set back /etc/tor/torrc to orginal
installed tor-geoip tor-resolve
disabled gl-admin-more-settings-customdnsserver-Override DNS Settings for All Clients
not sure exactly what fixed it.
if it was just having dns-overide setting enabled then may their should be in info description in tor section for user or needs fixing
