ponzi1
October 29, 2020, 9:42am
22
Need to check remotely using anydesk or teamviewer to understand the problem.
Oh no, never allow remote access to my PC. Please, tell me files to check and ideas to try. I use same file you use. I check sum (c26…). I upload. It say success. I enter GL UI. I go Tor. I click Apply. Can not access GL UI. I asking for troubleshooting, not for someone to enter my PC.
3.105-1014
https://dl.gl-inet.com/firmware/ar300m/nand/testing/
Exists two files have this name. Exact filename please?
alzhao
October 29, 2020, 11:01am
23
It is the same firmware, one used for uboot, one used to upgrade in openwrt.
alzhao
October 30, 2020, 7:27am
25
Flash a firmware without reserving settings, then use a private browser tab to try again.
ponzi1
November 2, 2020, 5:59am
26
@alzhao
Very strange things.
I do not touch router for one week.
I boot to router and it have firmwares 2.? !! Why can this happen? I do not upload old firmwares.
I download new firmwares from GL.iNet download center .
I upload the tar file. It tell me not valid. Why is this? In past, I was flashing .tar.
Now I try .img. Accepts file but it tell me that file is too big (15.75) becuase only available 15.63.
So many strange things. Please help me understand. I never having problems before recent when I want upgrade 3.105.
ponzi1
November 2, 2020, 6:08am
27
Wow! Now I do reset and it boot back into other firmwares (3.105 not working) and not 2.x!
Was it possible I am correct about conflict NAND/NOR?
What I should do?
limbot
November 2, 2020, 6:47am
28
When you go to uboot do you get the option to choose either a NOR or NAND firmware? There an upload file for both.
Sorry don’t have my AR300M handy so can’t do you a screenshot …
Found one. Does it look like this?
ponzi1
November 2, 2020, 7:41am
29
More Wow. When I was in the correct firmwares (only did reboot) I try again upgrade firmwares. It is successful upgrade.
So then I go to Tor, and Tor is working the correct way.
So this is working. But Wow, so many issues.
(Did not try uboot)
alzhao
November 2, 2020, 8:00am
30
There are two firmwares in the router and it is really strange sometimes.
No more multiple firmwares!
ponzi1
November 7, 2020, 10:28am
31
Very strange! One time it boot into one. One time it boot into other. Not good!
This is good.
But I still have problem. Tor can not start now. Tor page in GL UI only say:
Initialization tor configuration
but it do nothing, nothing, after waiting a long time.
Am I only person who have problems with Tor on 3.105 on ar300m?
ponzi1
November 8, 2020, 3:03am
32
@alzhao There is some way I can delete other firmwares? Small one maybe? And use this space for some other things? And not have stupid problem where boots one, or other?
alzhao
November 9, 2020, 9:56am
33
Do you still have problems booting different firmware? Have you ever upgrade uboot?
If you upgraded uboot uboot-for-qca95xx/bin at master · gl-inet/uboot-for-qca95xx · GitHub
It should always boot into nand if nand firmware is there.
firemod
November 12, 2020, 9:01am
34
@alzhao I am not able to find tor in mt300a last nightly. Can you help me?
alzhao
November 12, 2020, 9:40am
35
