I see that we can enable Tor on the MT6000 Flint 2 Router.
It explicitly says that "When Tor is enabled, the following features will not work properly: VPN, DNS, IPv6 and AdGuard Home."
But this does not make sense because you should be using a VPN on the Tor Network, so Why is GL-iNet saying that the VPN will not work??
and I have a VPN installed inside the Flint 2.
There may be a misunderstanding here. When using Tor, the GL GUI -> VPN -> OpenVPN/WireGuard related functions cannot be enabled at the same time.
Since the Tor is also a VPN, it is mutually exclusive to other VPN functions.
Thank you for the clarification Bruce.
I could find that type of clarification on GL-Inet site and the description was too vague inside my admin panel.
thx
