I don’t suppose anyone knows the spec of the ribbon cable used in the Slate 7 for the touchscreen? I’ve broken the cable (completely my fault). Router still works fine, just the touchscreen doesn’t.
If there’s a part number or anything that would be great.
Because the flex cable is integrated into the full screen assembly, it cannot be replaced as an individual component. If a repair is required, the entire screen assembly would need to be replaced. Additionally, the screen contains GL-developed software, so third-party replacements are not supported.
Please contact our customer service team at cs@gl-inet.com to check whether a replacement screen assembly can be provided and to obtain a quotation.
