Traffic not passing when bridged to Meraki
I’m trying to bridge my AR-150 to my home Meraki wireless in WDS mode. It shows connected, yet will not pass traffic yet I see the counters incrementing on the interfaces. Firmware is 2.25 and router is brand new. I’ve defaulted and reset multiple times.
Can you still ssh to AR150 using its IP address got from your Meraki?
After SSH you may find more details, including network status and log.
Once I set it up and give it an IP, I can only get to it from the wired lan side. here is an IF config:
wlan-sta Link encap:Ethernet HWaddr E4:95:6E:41:81:92
inet6 addr: fe80::e695:6eff:fe41:8192%eth0/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:120 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:282 (282.0 B) TX bytes:16325 (15.9 KiB)
Where would I find the log?
use “logread” to get the log.
Seems your sta don’t have a ipv4 address.
